Hello guys...
I'm in a project where we put Arduino working together, and they gave me a job... Use Arduino Mega to read the Ardupilot's telemetry pins.
I know that these pins use the MAVlink protocol and I found some tutorials talking about the use of MAVlink in Arduinos, but they are all the same code:
#include <FastSerial.h>
#include "../mavlink/include/mavlink.h" // Mavlink interface
FastSerialPort0(Serial);
void setup() {
Serial.begin(57600);
void loop() {
/* The default UART header for your MCU */
    int sysid = 20; ///< ID 20 for this airplane
    int compid = MAV_COMP_ID_IMU; ///< The component sending the message is the IMU, it could be also a Linux process
    int type = MAV_TYPE_QUADROTOR; ///< This system is an airplane / fixed wing
// Define the system type, in this case an airplane
    uint8_t system_type = MAV_TYPE_FIXED_WING;
    uint8_t autopilot_type = MAV_AUTOPILOT_GENERIC;
    uint8_t system_mode = MAV_MODE_PREFLIGHT; ///< Booting up
    uint32_t custom_mode = 0; ///< Custom mode, can be defined by user/adopter
    uint8_t system_state = MAV_STATE_STANDBY; ///< System ready for flight
// Initialize the required buffers
     mavlink_message_t msg;
     uint8_t buf[MAVLINK_MAX_PACKET_LEN];
// Pack the message
     mavlink_msg_heartbeat_pack(sysid,compid, &msg, type, autopilot_type, system_mode, custom_mode, system_state);
// Copy the message to the send buffer
     uint16_t len = mavlink_msg_to_send_buffer(buf, &msg);
// Send the message with the standard UART send function
// uart0_send might be named differently depending on
// the individual microcontroller / library in use.
    delay(1000);
    Serial.write(buf, len);
    comm_receive();
void comm_receive() {
    mavlink_status_t status;
// COMMUNICATION THROUGH EXTERNAL UART PORT (XBee serial)
    while(Serial.available() > 0 )
        uint8_t c = Serial.read();
// Try to get a new message
        if(mavlink_parse_char(MAVLINK_COMM_0, c, &msg, &status)) {
// Handle message
        switch(msg.msgid)
           case MAVLINK_MSG_ID_HEARTBEAT:
// E.g. read GCS heartbeat and go into
// comm lost mode if timer times out
           break;
           case MAVLINK_MSG_ID_COMMAND_LONG:
// EXECUTE ACTION
           break;
          default:
//Do nothing
           break;
// And get the next one
And I got the problem like the others... An error that says that I need to declare the Fastserail.h before the Arduino's serial driver... I tried using the 1.6.8 IDE, so I went to the Ardupilot's 1.0.5 IDE... So I got a lot of other problems, talking about files missing like the "Betterstream.h" but are all they there.
Did I forget something else?
I used the Arduino.h before the Fastserial, what solved my fist problem, but created others, involving overriding virtual functions.
Have other way to use MAVlink on Arduino Mega?
