Ardupilot Mega IMU Shield problems
Hi all,
Today I was testing out my new Ardupilot Mega + IMU Shield.. when I was testing the IMU sensors with the software, using DEBUG SUBSYSTEM = 6, I saw that my Yaw values are very strange. Example data while moving the board:
 roll:0  pitch:-11  yaw:355
  roll:-1  pitch:-14  yaw:355
  roll:-1  pitch:-17  yaw:355
  roll:-1  pitch:-19  yaw:355
  roll:-1  pitch:-20  yaw:355
  roll:-1  pitch:-22  yaw:355
  roll:-1  pitch:-23  yaw:355
  roll:-2  pitch:-24  yaw:355
  roll:-3  pitch:-24  yaw:355
  roll:-3  pitch:-23  yaw:355
  roll:-4  pitch:-22  yaw:355
  roll:-4  pitch:-20  yaw:354
  roll:-5  pitch:-18  yaw:354
  roll:-5  pitch:-17  yaw:354
  roll:-6  pitch:-16  yaw:354
  roll:-6  pitch:-15  yaw:354
  roll:-5  pitch:-15  yaw:354
  roll:-5  pitch:-14  yaw:354
  roll:-4  pitch:-13  yaw:354
  roll:-4  pitch:-12  yaw:354
  roll:-3  pitch:-11  yaw:353
  roll:-2  pitch:-10  yaw:353
  roll:-1  pitch:-9  yaw:353
  roll:0  pitch:-8  yaw:353
  roll:0  pitch:-7  yaw:353
  roll:1  pitch:-6  yaw:353
  roll:1  pitch:-5  yaw:353
  roll:2  pitch:-4  yaw:353
  roll:2  pitch:-3  yaw:354
  roll:3  pitch:-2  yaw:354
  roll:3  pitch:-1  yaw:354
  roll:3  pitch:0  yaw:354
  roll:4  pitch:0  yaw:354
  roll:4  pitch:1  yaw:354
  roll:4  pitch:2  yaw:354
  roll:3  pitch:2  yaw:354
  roll:3  pitch:3  yaw:354
  roll:2  pitch:2  yaw:354
  roll:2  pitch:1  yaw:354
  roll:2  pitch:0  yaw:354
The roll & pitch values seem to be OK, but the yaw value seems to slowy decrease only.. Even when I move the board around the Z axis extremely there are no significant changes.
Anyone knows how to solve this problem?
  • Hi Doug,
    Thanks for you're help!
    I just debugged with test 17, my initial values are like this:
    1662.00 1678.00 1459.00 2035.00 2051.00 2486.00
    1662.00 1678.00 1459.00 2038.00 2051.00 2486.00
    1663.00 1677.00 1459.00 2036.00 2051.00 2485.00
    1662.00 1678.00 1459.00 2035.00 2051.00 2485.00
    1662.00 1677.00 1460.00 2037.00 2052.00 2484.00
    1662.00 1677.00 1461.00 2037.00 2052.00 2486.00
    1662.00 1678.00 1459.00 2035.00 2052.00 2487.00
    1662.00 1677.00 1460.00 2035.00 2051.00 2486.00
    1662.00 1677.00 1459.00 2039.00 2051.00 2486.00
    1662.00 1677.00 1461.00 2036.00 2052.00 2485.00
    1662.00 1677.00 1461.00 2033.00 2052.00 2487.00
    1662.00 1677.00 1459.00 2037.00 2050.00 2485.00
    1662.00 1677.00 1461.00 2038.00 2052.00 2486.00
    1663.00 1678.00 1461.00 2035.00 2052.00 2485.00
    When I start moving the board:
    - 1st & 2nd value are accelerometers i think (values are changing)
    - 3rd value is not changing at all
    - 4rd value (pitch) is working
    - 5th value (roll) is working
    - 6th value (yaw i assume) is almost not changing, only hops to a value around 2500 but always returns to the initial value (+- 2485) when i stop moving.
    Haris - I have added a debug test 17. Use it to verify that you are getting good outputs from your gyros, particularly the z axis. I just put it together quickly for you and haven't tested it, but it should be OK.
