Hello,
I have an issue with the Ardupilot Mega RC output pins not working. This is a reoccurring issue on a few of my boards.
I have tested one working Ardupilot Mega (older version no version number) controlling a servo, but when I transfer the code to the Ardupilot Mega (v1.4) the servo does not respond.
Test code for a UBLOX GPS and serial communication to the computer were successful. I think the problem is isolated to the RC outputs.
I have spent a lot of time looking through forums and doing searches. I have found a few that also have this issue but I never saw a solution for myself.
Can anyone help me determine where the error is coming from?
Best,
Zahid
Hello Zahid,
I'm also facing a similar kind of problem not with the RC output pins, but with RC input pins. It was working before but suddenly it stopped responding.
I ran the basic APM_RC library file, there this loop is not executed ""(if (APM_RC.GetState() == 1))"", i'm not sure whether it is an hardware issue or from software!!!!
RC pin posses high resistance still.
Board which i'm working : ArduPilot Mega 1280 v1.4
Thanks in advance..
Figured it and this is how I debugged it:
First checked it that the signal was coming through the RC output signals with an oscilliscope.
I was suprised it the signal was there, so I connected the servo signal to the rc output and the power on a seperate 5V line. The servo worked in this setup. The power rail was coming in at 2.7V.
I connected the esc with a lipo battery like you are suppose to and everything was working properly. I read that people were able to drive 2 servos from there usb but this was my faulty assumption.
What is really weird is that I tested this setup with an older version of the ardupilot mega board (no version number) and it worked fine. The new one (v1.4) must have different power consumption requirements.
