Ardupilot Mega short circuited
Hi, I have a problem. 10 minutes ago I was trying to attach ardu to my skywalker and organize the cables - I don't know what happened but i saw a spark right after i put it in (probably cables short circuited), smoke and bad smell. Ardu is powering up but when I  seperate it from IMU. So something had happened to imu. How can i check what have happened ?Could it be only fuses or could it be something worse ...
Visiually everything looks ok, exept of 47uf Cap on IMU board - which looks like burned.
I will appriciate any help. Sorry for my English
Greetings
Hubert
  • You could check for continuity with a multimeter; that should help identify the faulty component. You should try and isolate the batteries before you work on the cables next time. good luck
