Ardupilot stops working very often (software crash?)
Problem:When I switch to waypoint-mode (ch5 100%) the MUX-LED lights up and the servos starts reacting (OK).BUT, very often (about 40% of the case) the yellow STAT-LED goes off as soon as I enter WP-mode and everything stops working! No servo response att all.If I then switch OFF the autopilot the MUX-LED goes off and the yellow STAT-LED always starts flashing again.I can repeat this process many times and sometimes the STAT-LED keeps flashing, but suddenly it stops in autopilot/WP-mode! I guess the program crashes for some reason.It seem to be very unstable! Does anyone have any idea what it might be?I'm using the red ardupilot board (without the shield). I have XY- and Z-sensors, EM406 GPS. The board is powered from the ESC.I'm having the same problem even if I unplug the GPS, Sensors and servos.Software loaded:ArduPilot_Easyglider_V246Tested so far with success:- GPS navigation on the ground. Flash a LED when you hit a waypoint. WORKS OK!- Stabilization. Rudder and elevator responds to XY-sensor. WORKS OK! (only tested inside and the result are very unpredictable)RegardsTommy
  • Problem solved!
    Firts I resoldered the joints - I think they improved, but the problem was still there.
    I should have mentioned that I'm short on pigtails, so I had only CTRL and IN1 connected.
    But now I stole a pigtail and connected IN2 aswell. The moment i touched signal IN2 with the wire from the RX channel#2 the yellow STAT started to blink! It had "crashed" but now started to live!
    So, I soldered IN2 and now it's stable as a clock!!!
    I can recreate the situation I had by just disconnecting the IN2 from the receiver.
    Strange, but I'm happy! :-)
    Thanks!
    /Tommy
    Check your radio is sending out the correct PWM for the control switch. If it fluctuates, it could be reboot the board. Most radios have end point control. On my Futaba 7C I had to adjust this to get my channel 5 switch to output the correct PWM range. Bad GPS values from the config tool could also cause a hang and reboot. Reload your mission.
    Also you really need to connect Ch2 input or your setup won't work in a plane.
    Jason
    Re-solder CH2 signal out pin as it did not flow well... Also re-heat all 6 inputs pins, they look messy but are probably working fine.. all others look good. Are you only using one channel for now??
  • Thanks for the replies!
    I'v measured the voltage to 5.1V. Changed the ESC but the problem remains.
    I do not have the shield.
    How do I monitor ther serial port? I looked in the Arduino Serial port, but only gets garbage.
    Is there any useful debugging switch I can activate in the code?
    Here are some pictures of the board.
    Maybe I should resolder some connections...
    We haven't seen that problem with others. I'd suspect a low voltage situation or weak solder joint. Can you try to replicate the problem with the shield off, to eliminate those connections?
  • I'd open up a serial terminal, and post the serial output while you're switching between modes. You'll be able to tell a lot more.
