Arduplane V3.2.3 LAND_PITCH_CD Bug?
AutoTake Off and Land   LAND_PITCH_CD  no effekt.bin
After the flare point my delta wing plane goes to pitch close to stall. For that case we have the LAND_PITCH_CD which gives us the possibility to reduce the Pitch during the flare. I have tried so many negative numbers (starting at 0 and ending at -9000) but nothing has changed, as if the parameter had no effect. Is there a bug?
  • that param set the mininum pitch_cd but not the result, sometime, the result is larger than what you set.
    detail information you could check the wiki
