Hello,
I received my ardustation about a week ago and have been excited to start using it as a pan tilt mechanism in my ground station. I've seen people using ardustation as antenna tracking mechanism but can not find a full description as of how it works. I'm using a 2.4GHz Xbee on my arducopter to connect to Mission Planner but how can I have 2 xbee receiver to use in my computer as well as ardustation? Can I simply buy an extra xbee receiver and link it to my telemetry? Is there any where I could get extra information?
I also noticed that my ardustation is missing a xbee connection (as its shown below)
I got mine from www.udrones.com/ is this a easy fix or should I contact them? I guess to solder a new connector I should take the LCD out and re-solder it which wouldn't be fun at all :(
two last questions, where should I connect the servos for pan tilt mechanism and what software I should use to program the arustation!
Heres a link to the source code: http://code.google.com/p/ardustation-ii/downloads/list
Im pretty sure they forgot to add that sil connector. You can either send it back :(
Or if you are fairly adept at soldering, using a fine tip iron, add the connector without unsoldering the LCD...
