ArduStation for ArduCopter
I am working on adding in ArduCopter support for ArduStation.
One big problem I am having is parsing the CSV string.  From the documentation on the internet sscanf() allows me to parse a string, however, it only seems to work when I try to parse a CSV containing values which are integer and it doesn't work when parsing values that are float
This is the line of code
sscanf(buffer, "%f,%f,%f,%f,%f,%f,%f,%f,%f,%f,%f", &gyro_roll, &gyro_pitch,&gyro_yaw,&accel_roll,&accel_pitch,&accel_z,&roll_err,&pitch_err, &roll_angle, &pitch_angle, &yaw_angle);
buffer is the line of CSV received from the "Q" command on ArduCopter.
all variables are of type float
If I replace the %f with %d and make all values and variables integer it works fine.
I'm quite new to programming Arduino, and I know very little C and C++, most of my coding is done in Obj-C
  • Hi all .....
    May I ask experts ... In EZ-ground-station we connect the ground station with audio port in VRX (video receiver) to get the GPS data for tracking antenna pointing ...
    What is the same line in ARDU-STATION ??
  • Hai Tran:
     have you had any luck with the Ardustation / Arducopter. I would like to us it on my Quad and I am flying the ACM code. What firmware are you using ?
    Thanks Jack
    Still can't figure this out, but I managed to do a work around.
    I parse a float ie 123.45600 as two integers, so I get
    a=123
    b=45600
    Then I divide b  by 100000 to give me c=0.45600
    Then I reassemble a+c
