New to Pixhawk and Mission Planner. I'm confused.
When I look at the HUD in Mission Planner, the "% bad packets" number that is next to the sign strength indicator in the upper right hand corner is usually a very large number. It usually starts out in the 80% range then slowly over a few minutes increases to the 99% range.
The wiki says that this is the "% bad packets". Does that mean that 99% of the packets that are being transmitted are bad? The telemetry logs files seem to be accurate. ????
Am I doing something wrong? Is there a setting that I need to change?
Thanks in advance.
it should be the other way around.
mp shows % of good packets.
Thanks, I feel better now.
