Baro and Compass in terminal show no values?
Hey guys,
back at it again and i see .42! awesome.
does anyone know if there is a bug in mission planner when you jump into terminal and test command "altitude" or "compass" do they work?
when i do it, i see no values. do i have a hardware issue or is this a planner bug?
cheers,
paul.
keep up the great work guys!
  • haha. thanks mike! i tried touching the baro and blowing into it. nothing! my compass is in the recommended config with pins soldered to board. i am totally dumb founded on why these sensors have stopped working. Someone PLEASE help!
  • hi mike, thanks for your diagnostics ! very detailed.  however no luck on my end?! strange, i pretty sure it was working in the past! now its just giving me this.
    compass:
    Heading: 347, XYZ: 0,0,0
    and for altitude:
    Baro: 0cm
    all this while in CLI mode, GPS light on and Green "A" light on.
    any clues?!
    2.0.42 on my hardware does produce data for test/altitude and test/compass.
    Details of testing: I took an APM which was running ArduPlane, loaded 2.0.42 from Planner 1.0.67. No airframe, I do have a magnetometer hooked up, but no sonar, no ESCs, no rail power, no RX, no GPS (this last item might be important, it is plausible, not having read all the code, that you might have a GPS that has not fix, and some form of mixing is resulting on no results for compass or altitude. If I were to guess, however, from having read other CLI/Test code, I would bet against this "plausible" theory.)
    I switched it to CLI and Terminal, but it just told me to setup first.
    I used setup to enable the magnetometer and "+" mode, nothing else.
    I switched to Terminal, CLI/Log Switch and here is the rest. It works for me:
    NOTE: You must disconnect and move the slider switch when done to use other tabs
    Opened com port
    Init ACM
    RAM: 2574
    FW Version 107
    Entering interactive setup mode...
    Type 'help' to list commands, 'exit' to leave a submenu.
    Visit the 'setup' menu for first-time configuration.
    ArduCopter 2.0.42 Beta] test
    test] altitude
    Hit Enter to exit.
    Baro: 0cm
    Baro: -60cm
    Baro: -60cm
    Baro: -69cm
    Baro: -78cm
    Baro: -78cm
    Baro: -87cm
    Baro: -104cm
    Baro: -113cm
    Baro: -130cm
    Baro: -130cm
    Baro: -139cm
    Baro: -156cm
    Baro: -156cm
    Baro: -165cm
    Baro: -165cm
    Baro: -165cm
    Baro: -165cm
    Baro: -174cm
    Baro: -174cm
    Baro: -174cm
    Baro: -156cm
    Baro: -156cm
    test]
    test] compass
    Hit Enter to exit.
    Heading: 14, XYZ: 203, -92, 182
    Heading: 14, XYZ: 202, -93, 182
    Heading: 14, XYZ: 203, -93, 183
    Heading: 14, XYZ: 203, -93, 182
    Heading: 14, XYZ: 203, -92, 183
    Heading: 14, XYZ: 202, -93, 183
    Heading: 14, XYZ: 202, -92, 183
    test]
    Terminal-> test, on Mission Planner is basically a serial terminal link, so if you get far enough to type "test" and "compass" then it would have to be an ArduCopter issue, hardware or software, if it is not giving you data you expect. I'll fire mine up at see what data I get w/ 2.0.42 right now...
