  • Hi,
    It's telemetry log, right? It has got to be this, from Log.pde:
    static void NOINLINE send_raw_imu2(mavlink_channel_t chan)
        mavlink_msg_scaled_pressure_send(
            chan,
            millis(),
            (float)barometer.get_pressure()/100.0,
            (float)(barometer.get_pressure() - barometer.get_ground_pressure())/100.0,
            (int)(barometer.get_temperature()*10));
    Temperature is:
    float AP_Baro_MS5611::get_temperature()
        // callers want the temperature in 0.1C units
        return Temp/10;
    and the Temp variable is in 1/100 degrees C. So the log data appears to be 100ths of degrees C divided by 10, truncated and then multiplied by 10 again ... that is, in 100th of degrees C but rounded down to nearest lower 1/10 degree.
    Pressure is returned by the function in AP_Baro:
    get_pressure() : return pressure in mbar*100 units
    and then divided by 100 in Log.pde, so it appears to be mBar = hPa.
    Which sort of numbers do you see, is it consistent with this?
    Regards
    Soren
