Baro pressure module smd500 only $39
Here is a little gem I found but I am not too good at i2c communications.It is an smd500 baro pressure module that runs on 3.3 vdc. Anyone had any experience with this part ? I am going to use it for altitude in my autopilot I'm developing.http://www.quadroufo.com/product_info.php?products_id=41&osCsid=8fec2f64c5dc7adf384fa1d8a5ac3a30
  • Earl, you may want to try the BaroMod, same cost, but provides a linearized output, 0.25mV per foot, so you
    don't have to do nasty math to get a real alt. In hardware, an anti-log amp, the correct voltage is output to your
    a/d input. The atmosphere has a log pressure function, a bit hard to straighten out with bit banging in PICs , for sure.
    I have resolved a couple feet with this unit.
    Under products at:
    http://www.transolve.com/Transolve/index.html
    * The BaroMod allows easy altitude measurement using any 0-5V analog electronics or embedded processor, with at least a 10 bit a/d converter.
    * An anti-log amp is used to create a linear response. No complex software math is required to process sensor signal, freeing up computer for logging or telemetry tasks.
    * Typical usage with 10 bit a/d will yield 20' measurement steps, good for general purpose application. Higher res is ok.
    Size: 2.05" x 1.15" x 0.65"
    Weight: 17 grams
    DC Supply: 5V
    Range: -500' below sea level to 20,000'
    Output: 0-5V linear, proportional response, 0.25mV/ft.
    Modes: absolute,differential (subtract ground reading)
    Temperature Range: -40 to 200 deg. F
    Typ. usage: Feeding to 10 bit a/d results in 20' increments
    Price - US$38 + $5 ship
