hello guys,
Is it possible to attach two batteries of different mah, volt or C rating parallely???
Is possible to attach(parallely) two batteries of
-different C rating same mah and volt?
-different mah same C rating and volt?
-different volt same mah and C rating?
thank you.
You can parallel batteries as long as they are the same AH, same volts, same C rating,
