Battery Fail Safe Setup
As I understand the Wiki, a battery fail safe setting will only save the aircraft in certain ways depending on what mode it is currently flying in.  Is there a way to define what the safety action is when the low voltage failsafe is activated?  If not, can this be an option added to MP?
Also, I do not have the listed parameters in the Advanced Param list as shown in the Wiki (FS_BATT_ENABLE).  Does the throttle failsafe need to be activated as well in order to get these params to display (separate menu)?
  • good question!
    I hope it can be done.............let say aircraft switch RTL after reach low set voltage or RTL after current reach 70% of total mAh setting.............will be nice feature.
