Battery selection in APMSetup
Michael,
I have the AttoPilot Power sensor in my system.
The Battery selection allows us to select 'Volts & Current' monitor that changes BATT_MONITOR to 4 as it should.
But - the input pads do not accept entered data.  Can't enter Input voltage, Measured Battery voltage, etc.  The Battery Voltage value is 3.126.  Way too low.
When this works the way you intend, it will be a very valuable addition to a great tool.
Thanks for all the effort.
    In the past (I don't know if this is still the case w the new changes in MP for battery monitoring) you had to follow the instructions in the manual here, read to the bottom under "Instructions for setting up the APM code to use the AttoPilot sensor:"
    I see Michael has made changes under the Configuration->Setup for the battery monitoring in 1.0.75 (maybe 74 too?) but I have not tested them. Hope this helps.
