HI,
I am new member in the X-UAV Talon club, I have just received my Talon with the extension wing.
I'm working to put the right combination of motors, prop and batteries:
I am looking to have the maximum flight duration over 90 minutes.
The weight of my FPV gear with all antennas, cables, cameras is around 750g.
The weight of the talon + motors + ESC + servo is around 1400g, So the total weight without the batteries is around 2150g
Regarding the battery, I can use multiple options based on motors and prop:
Multistar Battery Weights:
3S 5200 mAh is 325g.
4S 5200 mAh is  433g.
Option1: 3S configuration 2 parallel batteries => 3S 10,400 mAh: 650g. Total flight weight 2,800g
Option 2: 6S configuration, 2 series batteries => 6S 5,200 mAh: 650g, Total flight weight 2,800g
Option 3: 4S configuration, 2 parallel battery => 4S 10,400 mAh: 866g.Total Flight weight: 3,016 g
Option 4:  3S configuration 4 parallel batteries => 3S 20,800 mAh: 1300g. Total flight weight 3,450g
Option 5:  6S configuration 2 parallel + 2 series  => 6S 10,400 mAh: 1300g.Total flight weight 3,450g.
What motors and prop should we use with every option, and what flight duration will we get?
I have those motors: but I can buy others if needed:
Motor 1: OSMG9530  http://www.osengines.com/motors/motors/motor-specifications.pdf
OMA-3825-750
 (.30 Size)
Rotor Diameter (mm): 38
Magnet Length (mm): 25
kV: 750
Watts: 590
Weight (oz/g): 6.7 (190)
Motor 2: Jamara E-Motor Magnum A2820/6
http://www.conrad.at/ce/de/product/428816/Jamara-E-Motor-Magnum-A28...
Specifications  Revolutions / v : 1000
Internal resistance : 59mOhm
Idle current: 2.0A
Max A: 37A / 60S
Shaft Diameter : 4.00mm
Output: 550-Watts
NiMH Battery : 8 ~ 14
LiPo Battery : 3 ~ 5
Propeller NiMH: 11x8 Propeller LiPo : 3xLiPo 11x6 / 10x7 4xLiPo
Application: 1000-2500g
Motor 3: Emax BL2826/06: http://www.toysonics.com/emax-bl2826-06-950rpm-v-outrunner-brushles...
Features
  • New Emax BL2826/06 950Rpm/V Outrunner Brushless Motor
  • Model: BL2826/06
  • No. Of cells: 3-4 Li-Poly
  • RPM/V: 950
  • Max. efficiency: 86%
  • Max. efficiency current: 20- 30 A (>78%)
  • No load current / 10V: 2.1 A
  • Current capacity 61 A/60s
  • Dimensions: 30x26 mm
  • Shaft diameter: 5 mm
  • Weight: 182 g/6.41 oz
  • Recommended model weight: 2-3.2 kg
  • Recommended prop without gearbox: 13*8; 12*8
Elios
        • "Talon" has wings, and a motor at the back.
          "Toys" have 4 motors on top, and the less said, the better :-(
          It's a translation problem.....
  • Hi everybody !
    My frame is a Talon V2 and i've currently two LIPO 5S 5000mah 45C and i would like to know, if i put them in series (5S 10000mah), how many times will be the flight time?
    I don't have motor yet, which model is better for 17" 5,5 props to have a good thrust (more than 2kg/motor) with good autonomy ?
    Thanks at all
    • Joffrey, you have made a fundamental mistake, in series, you will have 10S, 5000 mAh.
      At the typical current a Talon draws. there is almost no advantage to go to high voltages.
      My Talon now flies with 3 x 3S 5000mAh pack in parallel, carries 500g of payload, at 60 Km/h airspeed, flies for guaranteed 60 minutes, can push that safely to 90 minutes..
      In cruise, Talon draws average 7 A.
      Advantages, no fancy motors, no fancy ESC's, no fancy BEC's, most video TX's run on 3S......
      • Oh sorry, yes it will be in parallel
        The spped is not very important for me, i prefer to have a good thrust
        Woah 90 minutes, it's awesome !
        Which motor do you use?
        • Turnigy 3548 900Kv, APC 12x6 electric prop,
          Because I had it from a previous project !
        • 100KM
          Joffrey, is your goal maximum duration or range?  Why the 17X5.5 propeller?  Why 5S?
          • 50 minutes will be verry good !
            17x5.5 because i've take the extension for the talon V2 frame and 17" give more stability and flight time and i need of this to do FPV.
            5S because i already have the batteries for another rc (MT4 G3).
            • you will break the prop if 17" everytime you land.
              You don't need more than 13" and you will get 60 minutes minimum, you saw my summary and it was a flight full of circles which means it has consumed more energy than cruise mode.
              it's Ok for 5S, your AMP will be like 3 most of the time.
      • Hi Gustav,
        Are you using the extension wing? I guess you should be able to do more than 2 hours if you are flying at 45km/h cruise speed.
        I used only 5,600mAh out of 12,000 mAh of my 2 x 3S.  My flying weight was around 5KG.
        We did not even do cruise to get better time but only circles with a radius of 150m and we flew for 56 minutes on 2 batteries with a concumption of 5,600 mAh.
        3702690172?profile=original
        • Yes, I have the wing extensions.
          At the moment everything is set up for 60 Km/h, I did not gain much current wise to drop the airspeed to 40, and I wanted to cover as much ground as possible.
          Lost my flying field, so I'm not doing much at the moment.......
