Best tricopter layout
I see arducopter has two possible tri-copter options; which is best? And what does it mean when the second option "doesnt need a code change"?
It's for a small 300mm foldable - the HK trifecta to be specific.
  • 3701926316?profile=original
    Built it...a problem with the servo not returning to centre needs fixed before maiden. Oh, and the FPV wired in. A very tight fit for everything.
    https://storage.ning.com/topology/rest/1.0/file/get/3701926316?profile=original
    • Euan - how did you go with you Trifecta? I am halfway through a build on one of these at the moment and am keen to know about your experience.
      • Not that great if I'm honest.
        I had to decouple pitch and roll and tune them seperately. I can get a stable D rate of 0.003, which seems to be the most APM can cope with at this form factor (I have the same in a mini hex and a quad). I am still experimenting with PI rates; I can get it to "full sticks", but it's a long way from being "locked in".
        Pitch seems to be the main issue; in high speed turns it wallows a lot. Straight ahead, not so bad, but throw in some roll, and it starts to oscillate on pitch.
        • I finally repaired the diode issue with my Mini APM V3.1s (Purchased from RTFQuads) and finished setting up my little trifecta.
          3702783468?profile=original
          To be honest I am pretty happy with the results so far.
          I started with some basic tuning in the living room that provided reasonably good flight characteristics (just a little wag and wobble).  I did my first autotune flight today and got a pretty nice tune first go!  There is still a little waggle in the tail, but it otherwise feels just as solid as any of my other multis.
          BTW - Perhaps your choice of prop is limiting the quality of the tune you can achieve. NOTE - I initially assembled with 7x4 HQ props but it was oscillating all over the place and quite a bit over powered with those props, so I switched to 6x3 Gemfans.  Notably, the osilations reduced dramatically when switching to the smaller and more flexible Gemfans (without any change to the PIDs - which I don't quite understand).  I will be interested to see whether the oscillation return when I switch back to the 7x4 HQs (and will report back in case you are interested).
          • soy de venezuela me interesa comunicarme Directamente con su persona. Tengo un desarrollo de DRON. pero lo que no quiero es que lo utilicen con fines belico. puede capturar aeronaves en pleno vuelo.si se desarrolla a escala como un ALA DELTA.y capacidad de remolcador dependiendo su desarrollo. acabaria con todo los aviones del mundo.SU NOMBRE ES EL VUELO DEL MURCIELAGO. IDENTICO SU CAPACIDAD DINAMICA DE VUELO. ELTOVY@GMAIL.COM
            vuelo.si - This website is for sale! - Vuelos Resources and Information.
            This website is for sale! vuelo.si is your first and best source for all of the information you’re looking for. From general topics to more of what y…
        • Hi Euan,
          Thanks for your update. It is a shame to hear that you have had limited success. It seems you are not the only one though, as it appears that APM powered trifectas are somewhat difficult to get right. I am not actually aware of anyone who has achieved a well tuned setup to date.
          My trifecta build is now on hold unfortunately. It appears that two mini APM V3.1s I purchased a while back have manufacturing faults relating to incorrect diode selection. The problem resulting from this issue is a full 1VDC drop between my power module and reciever, which is no good at all. I am awaiting a response from the supplier at this point in time.
          Having gone to some trouble fitting everything including a cut down power module into the limited internal space available in the Trifecta I am quite keen to persevere with using an APM on this frame, but may perhaps end up grabbing a Naze32 to get this cool little frame in the air.
  • I wonder why APM:Copter does not support Y6 with one arm forward and 2 arm backward like a reverse Y. Such configuration may result in less drag than Y.
  • Euan, why don' t you try both and let us know ?
    IMHO the one with opposite prop will have a bit less torque.
    Let us know
    • I prefer the arrangement with the two opposing props. There will be less torque the tail rotor needs to compensate for. And if you are using an RCExplorer type servo/motor hinge, they often have limited travel before they hit their stops. I'd rather not use this limited travel to have to compensate for torque I can eliminate by using counter rotating props.
      • This is the one I've gone for.
        There's something faintly disturbing about a multirotor that has all its props turning the same way...:-)
