Hello from Germanyit is normal that the ArduPilot Bord heat is on the bottom?Unfortunately, the ArduPilot Shield does nothing more.Beginning to have shone even the GPS lampBut now, no LED lights on the ArduPilot Shield.Have I made the Przessor off?Thanks for your helpPeter
Hello,
Unfortunately, I have not found a short circuit!
wath I found is the ground wire to pick up the Accupower was soldered to a outpin ! upssss !!
have i destroyed the board ??? i hope not the GPS and the Sensors or the ArduPilot Shield
I ordered a new ArduPilot Bord!
I also can not upload a new Programm !!
It sounds to me like a short as well. The boards should never get hot at all. Check your power connector and look for any possible frayed connections on the shield connectors. Also look to see if any soldered connections are touching together creating a short.
Greeting and thanks
Peter
