broken apm1 board?
Hello, a friend of mine just gave me this APM 1 board.
the mission planner cannot connect or program it, I also tried with an USBASP on the ISP connector of both atmega2560 and 328 but the answer is always "target doesn't answer". when powered a red led is lit.
where can I start to look for faults? is it worth? I mean, if I can fix this board, will I be able to run all the latest firmware or is it already obsolete?
thanks
Enrico
  • If it will help, here is a partial power schematic I made in October 2012...
    3692783623?profile=originalGood luck!
    -=Doug
  • There were two discussions (cannot remember when) about APM1 and no function.
    Both problems were open pcb traces on the Output header into the APM.
    Searching is somewhat hit-or-miss at times.
    -=Doug
