Posted by doodapunisha on November 23, 2013 at 2:17am
Hi all, what is the best old version software to use, to counter act this regulator problem until you clever guys can fix it in the next ones? Thanks in advance.
I'm not sure there's going to be a software fix that can solve the hardware problem. We may be able to find a workaround, but you can't ignore the fact that it's not a good idea to fly on hardware you know is malfunctioning. You might be able to justify it if you are flying a cheap quad in a safe place. But I sure wouldn't recommend you use an APM with a blown 3.3V Reg on an expensive machine.
Probably just best to stick with 3.0.1 stable.
