Broken uBlox?
Hello All,Well, I tried to repair my uBlox antenna, and I'm not sure it went that well.I downloaded u-center, and when I use the same port settings I use to connect to ardupilot, I get this in the "Packet Console". Doesn't seem good, should this app just fire right up with the right port settings?
  • Hi all
    I know this is an old thread - but think i've got a ublox module playing up (bought from the diydrones store a year or so ago)
    has been working flawlessly, did some firmware upgrades. used it in ubx and nmea modes at differing baud rates etc etc.
    then, it hasn't been used for a month or so, and all of a sudden it's not giving much out at all. managed to get some info from the output window in ucenter and ran the diagnostics tool in the program. any ideas anyone?
    ??:??:??  $GPTXT,01,01,02,ANTSTATUS=DONTKNOW*33
    ??:??:??  $GPRMC,,V,,,,,,,,,,N*53
    ??:??:??  $GPGSV,1,1,00*79
    ??:??:??  $GPGLL,,,,,,V,N*64
    ??:??:??  VER 6.01 OPT 00000001
    ??:??:??  ERROR: failed polling 00000a02 00000000
    ??:??:??  ERROR: failed polling 00000a04 00000000
    ??:??:??  ERROR: failed polling 00000a06 00000000
    ??:??:??  ERROR: failed polling 00000a07 00000000
    ??:??:??  ERROR: failed polling 00000a08 00000000
    ??:??:??  ERROR: failed polling 00000a09 00000000
    ??:??:??  ERROR: failed polling 00000a11 00000000
    ??:??:??  ERROR: failed polling 00000a1b 00000000
    ??:??:??  ERROR: failed polling 00000a1c 00000000
    ??:??:??  ERROR: failed polling 00000a1e 00000000
    ??:??:??  $GPGGA,,,,,,0,00,99.99,,,,,,*48
    ??:??:??  $GPVTG,,,,,,,,,N*30
    ??:??:??  $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99*30
    ??:??:??  ERROR: failed polling 00000a1f 00000000
    ??:??:??  ERROR: failed polling 00000a20 00000000
    ??:??:??  ERROR: failed polling 00000600 00000000
    ??:??:??  ERROR: failed polling 00000603 00000000
    ??:??:??  ERROR: failed polling 00000606 00000000
    ??:??:??  ERROR: failed polling 00000607 00000000
    ??:??:??  ERROR: failed polling 00000608 00000000
    ??:??:??  ERROR: failed polling 0000060a 00000000
    ??:??:??  ERROR: failed polling 0000060c 00000000
    ??:??:??  ERROR: failed polling 0000060d 00000000
    ??:??:??  ERROR: failed polling 0000060e 00000000
    ??:??:??  ERROR: failed polling 0000060f 00000000
    ??:??:??  ERROR: failed polling 00000610 00000000
    ??:??:??  ERROR: failed polling 00000611 00000000
    ??:??:??  ERROR: failed polling 00000612 00000000
    ??:??:??  ERROR: failed polling 00000613 00000000
    ??:??:??  ERROR: failed polling 00000616 00000000
    ??:??:??  ERROR: failed polling 00000617 00000000
    ??:??:??  ERROR: failed polling 0000061a 00000000
    ??:??:??  ERROR: failed polling 0000061b 00000000
    ??:??:??  ERROR: failed polling 0000061d 00000000
    ??:??:??  ERROR: failed polling 0000061e 00000000
    ??:??:??  ERROR: failed polling 0000061f 00000000
    ??:??:??  ERROR: failed polling 00000620 00000000
    ??:??:??  ERROR: failed polling 00000621 00000000
    ??:??:??  ERROR: failed polling 00000623 00000000
    ??:??:??  ERROR: failed polling 00000624 00000000
    ??:??:??  ERROR: failed polling 00000625 00000000
    ??:??:??  ERROR: failed polling 00000628 00000000
    ??:??:??  ERROR: failed polling 00000629 00000000
    ??:??:??  ERROR: failed polling 00000630 00000000
    ??:??:??  ERROR: failed polling 00000680 00000000
    ??:??:??  ERROR: failed polling 00800000 00080000
    ??:??:??  ERROR: failed polling 00200000 00070000
    ??:??:??  ERROR: failed polling 00400000 00024000
    ??:??:??  ERROR: failed polling ffe40000 0000004c
    ??:??:??  ERROR: failed polling ffa00000 00000088
    ??:??:??  ERROR: failed polling fff40000 00000020
    ??:??:??  ERROR: failed polling fff60000 00000020
    ??:??:??  ERROR: failed polling fffff000 00000104
    ??:??:??  ERROR: failed polling ffe60000 0000001c
    ??:??:??  ERROR: failed polling fff80000 000000cc
    ??:??:??  ERROR: failed polling ffee0000 00000020
    ??:??:??  ERROR: failed polling fff00000 00000020
    ??:??:??  ERROR: failed polling ff600800 0000006c
    ??:??:??  ERROR: failed polling ffec0000 00000040
    ??:??:??  ERROR: failed polling ffe80000 0000004c
    ??:??:??  ERROR: failed polling fff20000 00000010
    ??:??:??  ERROR: failed polling ffea0000 00000054
    ??:??:??  ERROR: failed polling fffc0000 00000060
    ??:??:??  ERROR: failed polling fffa0000 00000010
    ??:??:??  ERROR: failed polling ffc00000 000004c0
    ??:??:??  $GPTXT,01,01,02,EXT CORE 6.02 (36023) Oct 15 2009 16:52:22*47
    Looks like jordi was using ublox firmware version 5 for this configuration file, and you have version 6 factory loaded.
    If you play with the u-center interface a little, It gets easy to configure. But it is hard to get started with.
    The configuration viewer is were you save a setup to uBlox, So when you remove power It will remember all setting, if you don't write changes they will be lost. This is very good software interface.
    Try the "messages" viewer in Ucenter. It will show what messages the Ublox is outputting, and also allow you to poll other message types. Very useful for diagnostics. Also, through the configuration viewer you can view and change the current configuration.
    John,
    Upload this to Ardupilot and check it out in the Arduino serial window. It should output location data.
    ublox_tester.zip
    https://storage.ning.com/topology/rest/1.0/file/get/3692000766?profile=original
