I am using UT-2217 motors (http://www.unmannedtechshop.co.uk/brushless-motor-2217q-880kv/), AutoQuad ESC32 v2 (http://autoquad.org/wiki/wiki/aq-esc32/esc32/) and 4 cell LiPo. I have uploaded the firmware for the ESCs and now I am trying to calibrate them. However, the motor does not want to start spinning with a 12x4.5 propeller recommended by the motor manufacturer. When I start the calibration I get scraping noises from the motor and very small oscillations (no spinning). In a few seconds the ESC stops the calibration as the motor won't spin. When I try without the propeller, the motor spins fine. I tried with a 11x4.7 as well: the motor again gives the scraping noises and the oscillations in the beginning, but in the end it starts spinning... I am connecting via FTDI to the ESC(ABC leads of the ESC are connected to the motor and the PWM is not connected to anything). I get exactly same behaviour no matter whether I run the calibration program from AutoQuad or I just try to spin the motor manually via command line.
I also tried different decoupling capacitor values for the ESC - 330uf, 800uF, 1270uF, but still the same.
Any idea what might be the issue or suggestions to debug/fix?
Thanks so much, that did it!
I tried your suggestion and the motor indeed started after I gave it an initial push. ESC32 has an ADVANCE value in its control table and I tried every possible integer, but the motor still refuses to start on its own.
I ran the calibration software provided by AutoQuad (manufacturer of ESC32) with an 11x4.7 propeller. I then tried putting the 12x4.5 propeller, but it still refuses to start. Here are the current values of the control table of the ESC. You can find a reference here (http://autoquad.org/wiki/wiki/aq-esc32/esc32/esc32-configuration-an...). Do you have any suggestions what else I need to modify.
STARTUP_MODE = 0
BAUD_RATE = 230400 baud
PTERM = 0.250
ITERM = 0.00060
FF1TERM = +1.05532e-07
FF2TERM = +1.01535e-03
CL1TERM = +9.10266e-01
CL2TERM = +8.19136e-04
CL3TERM = +1.12699e-01
CL4TERM = +8.19820e-05
CL5TERM = +5.62973e-01
SHUNT_RESISTANCE = 0.500 mohms
MIN_PERIOD = 50 us
MAX_PERIOD = 12000 us
BLANKING_MICROS = 30 us
ADVANCE = 15.00 Degs
START_VOLTAGE = 1.10 Volts
GOOD_DETECTS_START = 75
BAD_DETECTS_DISARM = 48
MAX_CURRENT = 0.0 Amps
SWITCH_FREQ = 20.0 KHz
MOTOR_POLES = 14
PWM_MIN_PERIOD = 2200 us
PWM_MAX_PERIOD = 25000 us
PWM_MIN_VALUE = 750 us
PWM_LO_VALUE = 1000 us
PWM_HI_VALUE = 1950 us
PWM_MAX_VALUE = 2250 us
PWM_MIN_START = 1100 us
PWM_RPM_SCALE = 6500 RPM
FET_BRAKING = 0
PNFAC = 10.00
INFAC = 0.15
THR1TERM = +0.00000e+00
THR2TERM = +1.00000e+00
START_ALIGN_TIME = 600 ms
START_ALIGN_VOLTAGE = 0.90 Volts
START_STEPS_NUM = 0
START_STEPS_PERIOD = 16000 us
START_STEPS_ACCEL = 0 us
PWM_LOWPASS = 0.00
RPM_MEAS_LP = 0.500
SERVO_DUTY = 16.0 %
SERVO_P = 0.050
SERVO_D = 0.000
SERVO_MAX_RATE = 1000.0 deg/s
SERVO_SCALE = 360.0 deg
ESC_ID = 0
DIRECTION = 1
Thanks, I will try
