MR60
The purpose of this posting will be to document the building of a video capable low vibration quad with FPV/OSD that flies for 1.5 hours.
- flight path range > 15 km (2km radius)
- max speed > 30 kph (capable of handling moderate winds)
- GoPro camera/video on gimbal
- optimal designed vibration dampened electronics platform
- fits in a suitcase
- quiet (will not disturb animal life)
It will document the following in installments:
- design validation
- frame+motor mount build
- propulsion system build
- vibration optimization method, test, and analysis
- vibration dampened EP build
- electronics build
- gimbal build
- battery optimization & build
- propulsion system optimization
- flight tuning
- flight & FPV test
- video test
                • MR60
                  sweet!  going more into debtors prison to eventually get out!
                  can you test both?  maybe cut four 10 cm long carbon tubes (sand, clean both). bond them at 90 degree angles to form a T with one drop(ish) of adhesive each.  let both cure for a week or temp cure the 2216.  then using a scale, rotate the handle bar of the T so that the leg presses against the scale (try to keep the angle of the leg to the scale the same in both tests).  slowly rotate the handle until the two pieces come loose.
                  OMG!  just looked at the price of the applicator gun.  Only 15 pounds.
                  • MR60
                    i'll do the test. Those damned chocolate mint eaters must hide something ! We'll find out.
        • MR60
          Thx for your kind proposal. I do not have a CNC so I would gladly accept motor mounts. I will most probably use the tmotor 3508 or 3510 that should be a perfect match for the mounts thickness and holes alignment?
          • MR60
            Any comments before i start cutting?
            3702832258?profile=original
            - (4) Motor Mounts 37 mm
            - Bolt pattern 25 mm
            - Inside hole ID 10,16 mm
            - (4) Tube Plugs OD 14mm
            • Thanks for your link.
              Forest is it possible to have the dxf file to cut in 3 mm carbon balsa sandwich for 16/19 mm motor fixes? I am using the rctimer 2814 motors. thanks in advance
              • MR60
                Schaich - I recommend that one with tabs because it has more surface area. But, you many not have enough motor mast.
                3702914409?profile=original
                My brother, Jim, that flies over granite rock, uses a double (one on top of the tube and one on the bottom).
                Motor Mount 16-19.dxf
  • MR60
    What will be your objective of two pixhawks (one Pixhawk will be mounted on the VDEP base and and a second Pixhawk mounted on the VDEP)? To compare vibrations on both ?
    • MR60
      to tune the mass of the VDEP (Vibration Dampened Electronics Platform) to the dampers, i need simultaneous reading on the frame and VDEP.  In this way, i can figure out the change in vibration at the VDEP.  the types of dampers will be swapped out, the quantities of each will be changed (3 to 6), the mass of the VDEP varied, all done at various throttle levels.  hopefully the result will be a table for how to choose the best dampers for your VDEP given the mass of the VDEP.
      the Pixhawk offers the advantage of dual accelerometers running at different input rates resulting in more reliable vibration data..
      once the VDEP is tuned for its mass, the second Pixhawk (the one on the VDEP) will be removed so the final build can continue.
      the other approach would have been to buy a second Extech Vibration Meter.  But at over $1,000, going with a second Pixhawk seemed the more miserly approach.
      • MR60
        Results of these analysis will be interesting. I use a cheap xcam vibration !easurememt device to tune the dampening of my gimbal. So far I had best result with the secraft silicon rings damping system.
        • MR60
          put one on order.  i'll test it too.
          really liked your post on your test.  will have to take a longer look and see how it was done.
