Building my future drone DIY
Good day mentors and friends,
I would like to build a drone with the following specs. Your suggestion and recommendations base on your expertise and experience will greatly appreciated.
Good day Guys, I'm Planning to build my own drone.
Permission to post admin.
Frame - Hobbyking -x650 frame
Specs:
Weight: 598g (frame only)
Width: 550mm
Height: 265mm
Ground clearance: 155mm (bottom of frame), 185mm (camera mount rails)
Motor Bolt Holes: 16~30mm
Motors
specifications.
Motor Kv..........................1800KV-RPM / Volt
Motor Size........................ 480 Class
Motor Stator......................22x17 mm.
No-Load Current (Io).........2.0 Amps
Max Continuous Current....30 Amps
Weight............................62 g
Outside Diameter.............30 mm
Body Length.....................35 mm
Shaft Diameter.................3.0 mm
Max Trust.........................1200 g.
or
Specifications
Motor Kv..........................1500KV-RPM / Volt
No-Load Current (Io).........1.5 Amps
Max Continuous Current....25 Amps
Weight............................55 g
Outside Diameter.............28 mm
Body Length.....................30 mm
Max Trust.........................700 g.
Battery
LiHV New Lipo Battery
CAPACITY : 2500mAh
VOLTAGE : 11.4 V (3.8V/Cell) Full Charge @ 4.35V/Cell
DISCHARGE CURRENT : 50C
CHARGE CURRENT : 10C
Flight Controller
Naze32 rev6 DOF
Power Distribution Board PDB
1 x Matek Systems PDB-XT60
ESC and propeller: need your suggestion
Thanks.
