Bullets or No Bullets in AC2 wiring
From previous forum threads on here I had understood that current thinking about bullet connectors was that they are a generally bad idea. The first response to "I had a strange flip" would be along the lines of "Have you soldered your wires and removed those bullet connectors".
I recommended a manual change to reflect this, but had a comment today from Jason saying
"I think you should use bullets. Just get some decent ones."
So I'm confused.What's the party line on this?
Rob
    I would stay away from banana type bullet connectors, and use instead collet style spliced contact bullets like XT150 6mm, Polymax 5.5, Polymax 4mm  or similar ones with large contact surfaces.
    I prefer to solder all power connections (except LiPo batteries ones) so that there is always a perfect contact regardless vibrations, oxydation or mechanical miss adjustment of connectors.
  • The bullets that come with the stock Arducopter motors arentgreat. They have a tendency to fail. My advice would be to not use them but to purchase some better quality ones if you wish to use them.
    Hope that helps
