Cable question
Do you carry or can you direct me to any pigtails or extensions to the cables for my telemetry cable and my GPS cable? I have a uBlox LEA-6H. Thanks
d
  • This is a discussion area focused on the APM support from the community. 3DR direct support is also available.
    It sounds like you have one of the cables from HERE (scroll down the page) and neither is long enough. 3DR also offers longer versions HERE.
    A single longer cable without adapters, if you can, reduces a possible failure point.
    I do not see another longer cable for the telemetry. The current listing is 12 inches long. The cable is 4 pin on one end, 5 on the other and uses the 'standard' servo type pins. There are crimp kits available to build a longer cable and reuse the shells if you wanted to go that route.
    -=Doug
  • Is this discussion for support from DIYdrones? I would really like an answer to this question.
  • Forgot to say I have an AMP 2.5
