Calibrating power module
Hello all, how are you?
I trying to configure the power module to right set the POWER FAIL SAFE
I changed to Attopilot 180, because i have 22,000 6S battery.
Starting device, and with no arm (only showing in MP) my battery percent remaining is decreasing, but my battery values are practically the same.
Please see PDF in attached.
in other hand, after configure attopilot 180 i see value in ampere (+- 26A) is this correct value ?, if i set the failsafe at 20% of current (4.400 mah) and voltage to 19.2V
device will fly decreasing up to 4.4 A ??
My setup is:
Frame: Tarot hexa TL6X001
ESC's : Hobbywing XRotor 40A 2-6S ESC
Props: T series 1855 Carbon Fiber
Motores (6): FPVMODEL MC4012 400KV I will change for tarot 5008 (340 kv)
Battery: GreatMax 6S 25C, 22,000 (2.686 kg)
Power Module: Attopilot 180
Thank you, regards!
Cristian
bat_values.pdf
