  • This is false,
    the Brushless motors increase current as you increase voltage, if i'm not wrong.
    so at 11.1v a motor takes 20A, it might take more than 20A at 14.8v.
    so you raise the voltage, and also the current.
    someone tell me if i'm wrong on this
  • Well I would like to test this but just wanted to make sure there weren't going to be any big problems like frying something with too much voltage or crashing because not enough :) I just have some good 6000mAh 25-50C nanotech turnigys that I would like to try. I can join two together for 14.8 or just try one.
  • 14.8V will not work with the 12" props? I'm using the larger kit motors. What is the problem with 12"?
    Curious what is the reason for not being able to use 7.4?
    The motors specify 2-4S LiPo.
    http://store.jdrones.com/product_p/ac2836358.htm
