log2%20%282%29.rlog
2014-07-11%2017-41-52%2039.log
2014-07-11%2017-41-52%2039.log.gpx
2014-07-11%2017-42-08%2040.kmz
2014-07-11%2017-42-08%2040.log.gpx
Can someone please help me read these logs and figure out what happened.  I am flying very close, maybe 75 feet away and for some unknown reason my tricopter switches to RTL and lands perfectly but I can't keep flying.
I have disabled the battery failsafe and ground station failsafe.  I tried to read the logs and I see "err flight mode 5" and "error failsafe radio-1" on another log I see "error failsafe radio-0" and "error failsafe radio-1".
I use a frsky tx module with telemetry that beeps when I am near the end of my range and it never beeped also when this happened I was flying in my backyard which is only 75 feet away at the most so I'm a little confused.  Any help would be appreciated.
I am using an apm 2.6 with external compass and gps on a tricopter modeled after RCexplorers tricopter build.
    I just checked the log, and ThrIn is at 0% when the drone goes into LAND with EV5,1. You have 0 stats reported by the GPS, so LAND is the only option.
    3702130093?profile=original
    You can load your log files in Droneshare and it will do an automated analysis
    • Droneshare's log analysis tool is broken as of the date of this post...
      Cheers,
      Bill
    • great thank you.
