Plugged in APM2 with supplied USB cord,
loaded the driver from the wiki onto Win XP,
checked port & port baud in device manager, port 6 & 115200
started MP v1.1.40, set Port (6) and Baud (115200)
Click connect, this times out, on the terminal window:
Please select a number between 0 to 9.
Press '1' Test MPMavlink Bad Packet (Len Fail) len 53 pkno 48
pass.
Press '4' Test GPS.
Press '5' Test Dataflash.
Press '6' For PPM/PWM input.
Press '7' Refresh Rate 25Hz.
Press '8' Refresh Rate 40Hz.
Press '9' Refresh Rate 10Hz.
Invalid input!
pass.
Press '4' Test GPS.
Invalid input!
MAv Data: len 0 btr 7
770 start
Not a 1280
Ideas/explanation?
Sorry, scratch that, didn't realize I had to first load the airframe firmware, then connect, not the other way around (weird)
