Can't disable pre-arm checks
I am trying to do some bench testing indoors.  I can not get the Pixhawk (v3.3) to arm no matter what I try:
1)  Disable prearm checks
2)  Make all flight modes non-gps modes
3)  Change GPS_TYPE to zero (meaning no gps)
4)  Change AHRS_GPS_USE to zero
After (1) did not work (I verified that writing the parameters worked), I added on 2, 3, and 4.  No luck.  I still get one type or another of GPS errors (speed, whatever) when I try to arm.  If I go outside (getting a good GPS signal), arming works.
Ideas?  Thanks...
Bill
  • MR60
    To help and inform other users who will have the same experience, the problem is not a bug but a "hidden feature" introduced in version 3.3.x:
    -in previous versions you would disable the pre arm checks in the corresponding menu (standard params) of mission planner
    -in version 3.3.2 (and I suppose future versions?) : doing the above step , AND you must also go in the full parameters list or tree or geofence menu , look for the parameter "Geofence enable" and set it to zero.
    I have tested it succesfully like that.
    • Thanks, your note helped me out 6 years later on version 3.4.6 using Mission planner 1.3.75. The parameter must now be set to 10 and it is now called FENCE_ALT_MAX (default 100). This must be set even if the geofence is disabled.
      Super annoying - you saved me a lot of time - cheers.
  • You probably need to disable the fence (I can't remember the exact name of the parameter).
    • This reply was deleted.
      • MR60
        Thx for the info. Too bad this new behaviour in 3.3.x remained undocumented.
        Further I do not see any reason  to not show explicitly, geofence with pre arm checks: I want freedom to configure as I wish to and be able to disable pre arm checks when I need to. The non developer user can't know from thin air how the code has been modified introducing new hard links between parameters.
  • MR60
    Hello,
    I noticed the same bug. it is impossible to disable the prem arm checks, although the parameter is set.
