I just soldered my APM up that I got from DIY Drones (Thing has been kicking around for many months).
I am getting an error message
"Cant detect your APM version. Please check your cabling"
FTDI drivers installed properly and on the correct comm port, I have deleted and it re-installs the drivers no problem. Using Windows 7 fully updated. Just can't get the Mission Planner (APMPlanner1.1.63-32.msi) to load the firmware into the APM. I am going to go over all of the solder joints with the iron just to make sure, they look fine however.
Yes got it thanks!! If anyone every get the same error message check your soldering!!!! I accidentally jumped two pins together, what a rookie I am! Thanks Chris. I am really excited.....
Try a different USB cable and, if possible, another PC. If that doesn't do it, you've probably made a soldering error.
