  • yes, it's officially not supported, but you can use the raw data, actually it output.
    but we suspect the quality of data is not good as M8T.  we have tested the M8N and M8T, both works in RTK.
    also FYI, you can check ours: tersus-gnss.com
    • Tersus funciona com o RTKLib, inclusive com um xbee-pro?
      the Tersus works with RTKLib, including in the xbee-pro, or mavlink?
    • thanks for the help!
      I'll be sure to check yours out :)
