I am posting this in hopes that I can get some help beyond the troubleshooting guide. After a bad crash and rebuild. I have been able to fly however after I did a rebind of the transmitter to the receiver I have not been able to fly. I believe that that has been corrected but now I cannot arm to fly.
My current situation.
I have a spectrum DX7s
I have a AMP 2.5 running v 3.0.1.
All the configuration has been done;
Firmware correctly selected for 'X' frame.
Radio calibration done.
I am able to calibrate the ESC per the instructions and they spin up in sync as I would expect. Once I disconnect the battery and reconnect is when I run in to issues.
the APM led's cycle blue red as you would expect. I Get a GPS lock and then as I attempt to arm (Throttle down and to the right for a few seconds), the red light illuminates briefly then instead of going solid it just goes dark.
Being novice here and scanning the discussion boards I am not able to find a thread with any next steps.
Any advice from an experienced user?
