Hello, I have just upgraded to 2.0.25, loaded via the Arduino IDE, and been through the First Time setup process successfully a couple of times. Radio values look good.
However each time I get to the part where I have to arm the motors, it doesn't happen. I disconnect all power, switch CLI switch to flight mode, connect the Lipo and the ESC 4-wire lead and wait for boot to complete. At this point the green light is flashing in sync with the white rear-motor light. (The other 3 motor lights don't work)
With Transmitter on, I hold the throttle stick lower right for a few seconds, but arming doesn't happen.
What could be wrong please?
Is your RC transmitter Mode 1 or Mode 2? If you're flying Mode 1 (Europe), you need to hold the left stick to the right while the the throttle (right stick) is at its lowest position.
Please see the manual for more detailed instructions.
