Choosing the right battery
Hi , i just recently began working on my quadcopter and was doing some preliminary calculations to determine which battery i will use. what i have4 Turnigy TR 42-40A 1050kv 35A Brushless Outrunner (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2100)4 Turnigy Plush 40amp Speed Controller (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=2165)and i was looking at this battery Turnigy 4000mAh 3S 20C Lipo Pack (http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9185)Here is what i came up with, to be safe i used the max load for the motor (35A) , since i have 4 , i need something that can output 140A.If two of the above batteries are hooked up in parallel, the new battery would be an 8000mAh 3s 20C. So 8000mAh*20= 160A140<160 so i should be safe right? however thats a lot of current, what could the wire gauge on the batteries and esc support that? Also if this is the case, i get that the battery will only last 3 minutes under the current configuration. Is my math and logic right?thanks in advanceAlan
  • Say also what propeller size, that makes all the load and thrust, usually hovering should take half throttle or less,
    depends of course weight. I think you are in safe side anyway.
