https://www.youtube.com/watch?v=mK7Kxbpy8Mk
https://www.youtube.com/watch?v=JAQNBjqyKAc
❤️️ Hello fighter pilots! ❤️️
Rock a new girl on your Radio!
I just released my new Free to Download Edgy Sound Pack for your Open TX transmitter's.microSD card
Direct Download Link ⫸⫸↯ http://air-war.org/edgy/Choppergirls%20Edgy%20SoundPack%20English%20for%20OpenTX.zip
Download Dir (if the above does not work for you): http://air-war.org/edgy/
Project Home Page: http://edgy.air-war.org
Read Me File: http://air-war.org/edgy/_ReadMe.txt
On Rotor Builds: https://rotorbuilds.com/build/26173
--- Quick install instructions ---
-- basically, you'll just be replacing /SOUNDS/en folder on your TX's microSD card with mine. That's it!
-- unzip the Zip archive to your desktop. You'll get a "SOUNDS" folder with another "en" folder in it
-- connect to your transmitter with a USB cable (or put your microSD in a card reader)
-- in My Computer, backup your old microSD cards /SOUNDS/en folder if you wish, or rename it to /SOUNDS/en_original , or... just delete it
-- drag and drop my new replacement /SOUNDS/en folder that you just unzipped
..... onto your microSD card drive using Windows Explorer
..... to simply replace your old /SOUNDS/en folder. (say yes to replace queries)
-- when done copying,,, disconnect safely from USB. you're done!
-- if you don't hear new sounds when power cycling your radio, make sure your radio "Voice language" is set to "English" in SYS: Settings:(gear icon)
-- Caveat: Note that if you don't use the other language sound packs, if you are pressed for space on your microSD card, you can delete them.
