Clarification for IR sensors
I am learning how to work with the X-Y IR sensor and I have a neophyte question. I power the IR sensors from the receiver, with Vout~5V from the BEC. The same source powers ardupilot (I guess it is denoted Vcc in the schematic, assuming that no external battery is connected).  So Aref=Vcc=Vout right? Then, I am correct in assuming that when the IR sensors are level, the output is Vout/2, and when read from an analog pin the pin reads 511 at level? Or does the IR board regulates the input V to its own 5V? The reason I am asking, is that if the IR board references to an internal (fixed) voltage, then a bias is introduced in one of the attitude signals, unless Aref is set to the same voltage.
I would assume that the IR references to Vout, and since Aref=Vout  fluctuations in Vout only affect marginally the resolution, but not the centering of the sensor. I am wrong?
Thank you
Alberto
  • Thank you. If the FMA are put together as the Paparazzi, a voltage divider supplies Vout/2 to one leg of the OpAmp. So at zero angle the sensor reads Vout/2. That makes sense.
    All necessary theory and specs are here.
