- Wire it up like the below. You don't need to use the ArduPilot shield, however use of the shield is recommended so that ArduPilot will have an airspeed sensor input. If you are using the shield there is no need to attach thermopiles! Attach your RC gear as normal.
If you put on the shield where do hook the wires coming from the IMU? I think to the header but I need to be sure for myself. Thanks......Dan
Looks like
IMU D8 to Shield D6
IMU FWD GND to Shield - (That is a minus sign) on Four pin Header parallel to Shield GPS Input. BLACK
IMU FWD 5V to Shield 5V of Four pin Header parallel to Shield GPS Input. RED
Then it gets a little confusing:
You have a four wire harness. The BLACK and RED are clear but the WHITE and YELLOW are blurry.
It looks like BLACK RED YELLOW WHITE on the IMU to BLACK RED WHITE YELLOW on the Shield. But the photo is blurry so it could be BLACK RED WHITE YELLOW on the IMU.
HENCE is it GRND 5V RX TX on the IMU to - 5V OUT IN on the Shield?
or GRND 5V RX TX on the IMU to - 5V IN OUT on the shield?
You also have another four wire harness, white blue red black that goes to a connector that is not hooked up to anything. What is the purpose of this wire harness? Did I miss something?
Lastly, is it possible to get the FTDI cable attached and the XBEE at the same time to the shield header? I was having a hard time doing diagnostics with the FTDI and the IMU attached at the same time using the previous wiring diagram.
Thanks in advance.
