Coaxial Props
Hi There,
I'm a neebie
I'm setting up my first coaxial octocopter , wow
Are the props the same on the top motor's as the bottom motors. I have all the motors spinning as they should be
  • There needs to be half CC and half CCW (half pusher half puller). If you have two pullers and one motor is flipped for a coaxial setup they will just blow into each other instead of blowing down. In the wiki there's a page that shows frame setup as to where the CC and CCW props and motors should be.
    http://code.google.com/p/arducopter/wiki/APM2_Motor_order
