  • Hi, please raise a discussion in the visualmicro.com/forum letting us know which ardupilot software version you have loaded. let us have links to ardupilot software and libraries so that we canownload and reproduce your setup. Also confirm that you have the same system compiling in the arduino ide
    There are plenty of diyd folk using visual micro so we should be able to help you find the problem with your config :)
    Look forward to disccussing further on the vm site http://www.visualmicro.com
    Go ask Fab, he is a member here, and he wrote Visual Micro. If you want help compiling from the rest of us, use Arduino.
  • getting the following error when compiling in visual micro...
    I think its the problem with the library files not being integrated into the project.but i don't know where to put the library files in visual micro...
    Compiling 'ArduPlane' for 'Arduino Mega 2560 or Mega ADK'
    ArduPlane.pde : In function 'void init_home()'
    commands_logic.pde : 'gcs_send_text_fmt' was not declared in this scope
    ArduPlane.pde : In function 'void handle_process_nav_cmd()'
    ArduPlane.pde : In function 'void handle_process_condition_command()'
    ArduPlane.pde : In function 'void handle_process_do_command()'
    ArduPlane.pde : In function 'void handle_no_commands()'
    ArduPlane.pde : In function 'bool verify_nav_wp()'
    commands_process.pde : 'gcs_send_text_fmt' was not declared in this scope
    ArduPlane.pde : In function 'void do_jump()'
    ArduPlane.pde : In function 'void change_command(uint8_t)'
    events.pde : 'gcs_send_text_fmt' was not declared in this scope
    ArduPlane.pde : In function 'void process_next_command()'
    failsafe.pde : 'gcs_send_text_fmt' was not declared in this scope
    ArduPlane.pde : In function 'void failsafe_short_on_event(int)'
    GCS_Mavlink.pde : 'gcs_send_text_fmt' was not declared in this scope
    ArduPlane.pde : In function 'void failsafe_long_on_event(int)'
