Configuration file to ublox neo M8N (pixhawk)
Hello,
Does anybody have good configurating file to M8N. And may be somebody have a good tutorial, or can explain , how to load configuration file into u-center, to do some changes and save it again. Or easier way to create that file from zero.
Already tryied https://dl.dropboxusercontent.com/u/69142430/M8N%20shaggee.txt    this one, but half of messages didn't be correctly loaded,because something with versions in u-center
I need only gps logs ubx format file with time,lat,lon,alt,roll,pitch,yaw___and use gps/glonass mode.
Thanks a lot.
  • The only change that my Ublox Neo-M8N GPS with Compass seems to need is a wire change on the compass plug. I got 10 sats in 29 seconds, but I cannot get a green light on the Pix. The red wire on the compass plug from the HK M8N is in a different place from the 3DR Ublox compass plug. I would like see an official 3DR recommended setup on this before I fry something.
  • You should not actually need to set anything - pixhawk will send initialization commands to the M8N to set the main things such as baudrate each time it boots. There are some settings it may be worth setting through u-Centre, but they really aren't many and I have no idea whether they really make much difference.
  • The default settings should work well, so nothing needs to be changed. If you do change the configuration in u-center then you have to save it with >Receiver>Action>Save Config or it will be erased when you power off.
    You can change the configuration settings individually with u-center. You can set the dynamic model to airborne in the NAV5 config message. You can limit the messages you get with the configuration settings in u-center if you want only messages that have time, lat, lon, alt. Roll, pitch and yaw won't come from a GNSS module alone, you need sensors for these. GPS/GLONASS mode is set by default, so nothing would need to be changed for this.
    Here's some info from 3DR on how to load a configuration file. The config file they provide is outdated for the M8N. You can make your own file by changing the configurations in u-center that you want, and then using the GPS >> File option to save the set of options to a config file. Then you would load it in as they describe in the tutorial.
  • why do you need one? i just plugged my M8N to Pix and  it was worked fine w/o any config file....
  • Same for me too.
    I am total new on this :-)
    Thanks in advance.
Joseph Udofia liked Joseph Udofia's profile
yesterday
DIY Robocars via Twitter
Jan 28
RT @Heavy02011: ⁦@diyrobocars⁩ : A Home-brew computer club* for Connected Autonomous Driving. talk at #piandmore ⁦@PiAndMore⁩ on Jan 23rd h…
Jan 23
RT @a1k0n: New blog post! Deep dive into my ceiling light based localization algorithm which runs in 1ms on a Raspberry Pi 3: https://t.co/…
Jan 23
Great new guide to using @donkey_car https://custom-build-robots.com/donkey-car-e-book-en
Jan 23
RT @chr1sa: The next @DIYRobocars virtual AI race is tomorrow morn at 9:00am PT. You can watch live on Twitch https://www.meetup.com/DIYRobocars/events/275268196/
Jan 22
New version of Intel OpenBot! This resolves many of the issues with the first version, including a much smoother tr… https://twitter.com/i/web/status/1352395636369313798
Jan 21
DIY Drones via Twitter
Using ArduRover with an RTK GPS https://ift.tt/2N9I3RO
Jan 18
Jan 18
Jan 18
Jan 15
Jan 15
Jan 14
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
Jan 14
Jan 14
RT @Heavy02011: ⁦@diyrobocars⁩ Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ ⁦@f1tenth⁩ ⁦@DAVGtech⁩ ⁦@DWalmroth⁩…
Jan 11
