Configuration file to ublox neo M8N (pixhawk)
Hello,
Does anybody have good configurating file to M8N. And may be somebody have a good tutorial, or can explain , how to load configuration file into u-center, to do some changes and save it again. Or easier way to create that file from zero.
Already tryied https://dl.dropboxusercontent.com/u/69142430/M8N%20shaggee.txt    this one, but half of messages didn't be correctly loaded,because something with versions in u-center
I need only gps logs ubx format file with time,lat,lon,alt,roll,pitch,yaw___and use gps/glonass mode.
Thanks a lot.
  • You should not actually need to set anything - pixhawk will send initialization commands to the M8N to set the main things such as baudrate each time it boots. There are some settings it may be worth setting through u-Centre, but they really aren't many and I have no idea whether they really make much difference.
  • why do you need one? i just plugged my M8N to Pix and  it was worked fine w/o any config file....
    • Unfortunately the developers are clever enough to create obstacle with a GPS. It no longer is a straight forward thing !! Could you please share the configuration file for the Neo -M8 Ub-Blox model ....thank you
  • Same for me too.
    I am total new on this :-)
    Thanks in advance.
