Configuring telemetry radios
Having problems configuring telemetry radios: only bluetooth ports show on the connection dialog on my iMac and I cannot change the Com port on my PC from COM999,  which is the apparent default, to COM1 (or any other number for that matter). Ideas please! Yes, the drivers are installed and working on the PC
  • OK, OK. Problem solved (on the iMac at least). If you are running the lastest APM Planner then the instructions as found on the web are outdated. Do NOT use the connection top right on your screen. Go to Initial setup>3DR Radio and use the link setup on the right of the screen by clicking on the Advanced button. You can plug the remote radio to be configured into any USB power source - I used my cellphone.
