Connecting a RS232 converter to an ATTOpilot?
Hi Guys,
I've just tried to connect one of these to my ATTOpilot V3.
I hooked it up like this......
ATTO                                               TTL to RS232
Telm IN -------------------------------------------TX-O
Telm Out------------------------------------------RX-I
GND------------------------------------------------GND
                                                       VCC (3.3V input)
The 3.3V is scaled down from 5V like this.
I can't seem to get it to work?
Am I missing something?
Should I connect is differently?
It works great with a FTDI (USB) but I need it to work from a DB9 RS232.
(I want to try it over IP as I have a great little IP to serial converter that I use allot at work)
Thanks in advance!
Scott
  • Hi Scott!
    Do the Tx or Rx LEDs come on?
    Can you check that your 3.3V is in fact 3.3V when it is all powered up - I am worried that using a voltage divider to power a device will not give very good results.
    Cheers,
    Andrew.
