Hey guys, I am currently working on a university project and I was wondering if there is a way to interface the apm 2.0 board with the raspberry pi. Is a straight usb connection possible? The goal is to send APM GPS data to the raspberry pi board to be used in conjunction with image processing with openCV. Thanks for the help!
Hi Randy,
Working on the same. Any help apprciated.
Thanks & Regards
Randy said:
Hi Anderson,
Yes i would like you to share you information. Any help would be appreciated. I am interfacing the pixhawk to raspberry pi to get the imu and gps data.
Thanks and Regards
Sameena Shaikh
Jonathan Anderson said:
Hi Larsen,
What are the libraries you had to install and what kind of a connection was done by you.
Thanks & Regards
Tommy Larsen said:
Have you found those things you listed? I too am in need of it. Will appreciate any help.
Thanks & Regards
Shyam Balasubramanian said:
I am working on a similar project. Interfacing pixhawk to raspberry pi to get the gps data from pixhawk to raspberry pi so that i can use it for image processing on raspberry pi. Any help would be appreciated. I have just made the connection setup. . Didn't find anythin to move forward with. I have connected the pixhawk through the GPIO pins and powered the pixhawk through USB.
This is the thing i have been able to do till now. I could use mode to change modes, param set and show but couldn't find any command to get gps or imu data.
how did you do that i try everything can someone help me i connot download of fail the pymavlink
Hi All,
Need some HELP is it possible to map the USB link from APM2.5 to the RasPi using Mavproxy and route the telemetry info via UDP thru the Pi,then VPN through the 4g network ton the ground station or do i have to use the serial to LLC to telemetry port to get the data to the station.
I have attached image of how i think it should work.
Any help would be appreciated!!
Thx.
Are you making an object tracking Quadcopter?
Hi Jonathan,
I am trying to do something similar - connect an Odroid U3 to APM2.6's UART2 port. Can you give me some detail on how you did this, eg type/spec of headers, pitch. Is there an ready made FTDI USB cable I can get hold of for this?
How can I know when the RPi detects the pixhawk???
