Connecting APM2.5 Hardware
I am having difficulty with the APM 2.5 board that I just received. I can't seem to make sense of the older APM 2.0 board.
Here is the board that I have:
3690953772?profile=original
What I am trying to understand is where to connect the following:
PDB
Xbee
Do I connect the PDB to the green and blue?
Do I connect the Xbee to the URART0?
  • bump
  • The front of the APM 2.0 is different from the APM 2.5. The APM2.5 has a white 5 wire connector while the APM2.0 has std pins.
    Here is the front of my board:
    3692489270?profile=original
    I also read other posts by Vernon Barry that the UART0/2 does not work even after soldering the automux. Am I supposed to solder the automux and am I supposed to put a white 4 pin connector on the wires coming out of the xbee shield?
    So that is my point, I just want some good instructions. Is this something that someone from DIYDrones can update for us?
  • Just received mine and the Uart0 in the location upper right is prefered but there is a different conector that I have not yet identified. In the mean time attaching the Telm. to the optional Uart0 were you have it identified in red works fine.
    Jack
  • I would connect the Xbee to the UART0/2 that is in the top right of your image.  That matches the instructions where telemetry is hooked up.
    http://code.google.com/p/arducopter/wiki/APM2Wireless
