Connection APM2.6 to Raspberry Pi 3 with Mavproxy
Early, I worked with APM2.6 with Raspberry Pi B+, Raspberry Pi A+ and all works fine.
Now I try to connect APM2.6 to Raspberry Pi 3 and Raspberry Pi Zero and I obtaned the next problem:
1) I tryed to connect with usb port and command
sudo mavproxy.py --master=/dev/ttyACM0 --baudrate=115200 --out=127.0.0.1:5005 --cmd="wp load mission.txt"
2) I tryed to connect with telem port and command
sudo mavproxy.py --master=/dev/ttyAMA0 --baudrate=57600 --out=127.0.0.1:5005 --cmd="wp load mission.txt"
and
sudo mavproxy.py --master=/dev/ttyS0 --baudrate=57600 --out=127.0.0.1:5005 --cmd="wp load mission.txt"
And allways I see next result:
pi@raspberrypi:~/f1/go $ sudo mavproxy.py --master=/dev/ttyACM0 --baudrate=115200 --out=127.0.0.1:5005 --cmd="wp load mission.txt"
Connect /dev/ttyACM0 source_system=255
Loaded 5 waypoints from mission.txt
Log Directory:
Telemetry log: mav.tlog
MAV> Waiting for heartbeat from /dev/ttyACM0
So, mavproxy writes, that waypoints are loaded! But, when I check it using Mission Planner I can't see points. It writes, that points are loaded, but they are not.
Help me please to find the solution! Thank you!
  • Also I think you're trying to access the wrong device - ttyACM0 isn't correct for raspberry.  Try ttyAMA0 or ttyS0.  Ideally you should disable the bluetooth and use AMA0 as detailed in the link you've posted or here:
    http://discuss.ardupilot.org/t/connecting-raspberry-pi-to-pixhawk/9784
  • MAV> Waiting for heartbeat from /dev/ttyACM0
    ^^ This means you haven't got any connection to the FC yet.  'Loaded 5 waypoints' just means mavproxy has loaded them from the file mission.txt on your disk, not that it's loaded them to the FC.
  • Stephen, thank you for answer, but
    when I try to upload mission inside my python script, it's looking like this:
    child = pexpect.spawn("sudo mavproxy.py --master=/dev/ttyACM0 --baudrate=115200 --out=127.0.0.1:5005")
    ..waiting for heartbeat
    child.send('wp load /path_to/mission.txt\n')
    it is not working too,
    but with RPi A+ and RPi B+ with Raspbian Wheezy it works fine.
    Here is thread about same problem, but they hasn't find solution, only downgrade from RPi3 to RPi2 =)
    http://diydrones.com/forum/topics/mavproxy-ignores-input?id=705844%...
  • It's a bug in MAVProxy - you can't load waypoints via the --cmd="wp load mission.txt".
    There's a bug report at https://github.com/ArduPilot/MAVProxy/issues/142
    cmd not seeming to work for wp load · Issue #142 · ArduPilot/MAVProxy
    I have tried on 1.4.11(win), 1.3.13(win) and linux (latest) and I can't seem to get this to work. The command I have tried is "--cmd="wp load [fi…
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
