Connection APM2.6 to Raspberry Pi 3 with Mavproxy
Early, I worked with APM2.6 with Raspberry Pi B+, Raspberry Pi A+ and all works fine.
Now I try to connect APM2.6 to Raspberry Pi 3 and Raspberry Pi Zero and I obtaned the next problem:
1) I tryed to connect with usb port and command
sudo mavproxy.py --master=/dev/ttyACM0 --baudrate=115200 --out=127.0.0.1:5005 --cmd="wp load mission.txt"
2) I tryed to connect with telem port and command
sudo mavproxy.py --master=/dev/ttyAMA0 --baudrate=57600 --out=127.0.0.1:5005 --cmd="wp load mission.txt"
and
sudo mavproxy.py --master=/dev/ttyS0 --baudrate=57600 --out=127.0.0.1:5005 --cmd="wp load mission.txt"
And allways I see next result:
pi@raspberrypi:~/f1/go $ sudo mavproxy.py --master=/dev/ttyACM0 --baudrate=115200 --out=127.0.0.1:5005 --cmd="wp load mission.txt"
Connect /dev/ttyACM0 source_system=255
Loaded 5 waypoints from mission.txt
Log Directory:
Telemetry log: mav.tlog
MAV> Waiting for heartbeat from /dev/ttyACM0
So, mavproxy writes, that waypoints are loaded! But, when I check it using Mission Planner I can't see points. It writes, that points are loaded, but they are not.
Help me please to find the solution! Thank you!
  • Also I think you're trying to access the wrong device - ttyACM0 isn't correct for raspberry.  Try ttyAMA0 or ttyS0.  Ideally you should disable the bluetooth and use AMA0 as detailed in the link you've posted or here:
    http://discuss.ardupilot.org/t/connecting-raspberry-pi-to-pixhawk/9784
  • MAV> Waiting for heartbeat from /dev/ttyACM0
    ^^ This means you haven't got any connection to the FC yet.  'Loaded 5 waypoints' just means mavproxy has loaded them from the file mission.txt on your disk, not that it's loaded them to the FC.
  • Stephen, thank you for answer, but
    when I try to upload mission inside my python script, it's looking like this:
    child = pexpect.spawn("sudo mavproxy.py --master=/dev/ttyACM0 --baudrate=115200 --out=127.0.0.1:5005")
    ..waiting for heartbeat
    child.send('wp load /path_to/mission.txt\n')
    it is not working too,
    but with RPi A+ and RPi B+ with Raspbian Wheezy it works fine.
    Here is thread about same problem, but they hasn't find solution, only downgrade from RPi3 to RPi2 =)
    http://diydrones.com/forum/topics/mavproxy-ignores-input?id=705844%...
  • It's a bug in MAVProxy - you can't load waypoints via the --cmd="wp load mission.txt".
    There's a bug report at https://github.com/ArduPilot/MAVProxy/issues/142
    cmd not seeming to work for wp load · Issue #142 · ArduPilot/MAVProxy
    I have tried on 1.4.11(win), 1.3.13(win) and linux (latest) and I can't seem to get this to work. The command I have tried is "--cmd="wp load [fi…
