Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
It flies, but haven't done Auto Tune. EKF error, but no 'bad gyro health'.
It was nice flying with no errors for a considerable time, hopefully this will be addressed and fixed soon.
I recalibrated the compass, and still get the same high X offset on external.
I clicked update on the Help tab and seems to be gone now
Today I have the same error but I changed just MP (3.3 rc3)
Still getting errors on rc5
Question: what is the acceptable compass offset for the external compass? Is it +/-15 or +/-.25? I've seen both.
http://copter.ardupilot.com/wiki/common-diagnosing-problems-using-l...
http://copter.ardupilot.com/wiki/ac_compasssetupupadvanced/#live_ca...
I ask because this new GPS, a RTFQ M8N 45x45 has consistently high compass offset on x of 180+. The internal compass on this quad reaches 250, but there's not much I can do about it. On my other compasses the external offsets have never exceeded 100. Will 180 be a problem? I'm positive there are no ferrous metal sources nearby (same mast and base), and the GPS is ~100mm above the frame.
I bought a clone M8N from China which (a) didn't work and (b) had enormous compass offsets. I sent it back and put it down to poor manufacturing/design. The one I subsequently bought from RCTimer worked beautifully with low offsets. Draw your own conclusions :) My offsets were 700 or so though. 183 seems not awful in comparison.
I uploaded AC3.4 dev build this morning and gave autotune a 3 axis go. PID tuning changed quite a bit from 3.3 but results felt very good. This is on a 550 CF quad with pix, t-motors and Zubax gnss. The three axis tune took 16 min and was close to battery limit but completed successfully. Flew an FCF in loiter, alt hold, drift and stab with a couple RTL and land commands thrown in. I was very impressed with results, copter flew very well, predicable, stable and very responsive with RTL within inches of launch point and relative altitude very close throughout the test. I don't recommend jumping ahead of betas but it looks to me like you guys have the general flight code about nailed down. Thanks for all your hard work and dedication, this has been a great enjoyment for me over the last several months and has provided my High School class a tremendous learning opportunity.
Cheers,
RB
With RC5 I now get the error message "Error EKF POS VERT AGL" all the time. The quad (550 H Frame) flies fine in loiter, position, stabilize.
Steve
thanks pal for the feedback. It seems that this error does not affect the quad. though when using the Mission Planner, this error prompt is quite annoying :D hopefully this will get fix soon. thanks again!
I'm using MP1.3.27 build 1.1.5620.38044 and updated to rc5 and after that I did a "reset to defaults".
I choosed frame and then I tried to calibrate accel, the program steps from place level to left and then directly to right?
So I am unable to do the calibration...
I have uninstalled MP and reinstalled it and the same with the FW but with the same result?
I tried with 3.2.1 and then the calibration of accel was OK so it seems to be rc5, rc4 was OK.
374
375
376
377
378
of 449 Next
